How to make a table with all dimensions?
Sebastian_Galo
Sebastian_Galo
I'm thinking of a way to export all my dimensions in an assembly into a component table, preferably in the Drawing mode since a table already exists there. Is this possible to do without adding every dimension manually to the description under properties in the corresponding part?
I actually had the exact same idea as the person in this thread so it might be a good implementation if many wants it, and maybe isn't even that hard to implement? All the parametric values and names are usable in pretty much every aspect of fusion anyway as I know of, so it may be logical to do this move?
https://forums.autodesk.com/t5/fusion-360-design-validate/parametric-component-descriptions/m-p/9471...
Anyhow, is there a way of doing this at all automatically or am I stuck with my slow workflow?
Thanks in advance!
etfrench
The App store has an app called Parameter IO which will import and export parameters.  It might help automate this.
ETFrench
