How to make a simply suported beam in simulation?
Message 1 of 12
Dear,
I am trying to make a simply supported beam in the simulation mode of fusion 360.
But I am not sure witch kind of constraint I have to choose?
I fixed on in only on direction gives me a error of not enough constraint.
Prescribed displacement in on direction gives ma also a error in on direction.
I hope someone can help me out.
Thanks beforehand
Kinds regards
Replies (11)
Message 2 of 12
bluelife
You can constrain just an edge. So for a simply supported beam constraint you'd put a fixed constraint on the edge/edges of the beam
Message 3 of 12
If I use the fixed for a simply supported beam how can I than make a cantilever beam on both ends?
Thanks before hand
Kinds regards
Message 4 of 12
josef.kucera
Hi @Anonymous,
similar problem was already explained here: http://forums.autodesk.com/t5/design-validate-document/vertical-deflection-of-the-beam-simulation/m-...
Hope it helps.
Josef
Josef Kucera
Fusion QA
Message 5 of 12
Dear Josef,
I just have to make a simple cantilever and simply supported on the end of my beam.
But when I read the solution you give me I have to make Ux and Uy free but then a get a error that I have no enough constraint.
Can you maybe just say how I make in a easy way a simply supported and then a cantilever.
Thanks beforehand
Kinds regards
Oona Declerck
Message 6 of 12
josef.kucera
HI @Anonymous,
You could simply fix one end and add fixed constraint to the edge of the other end and left Ux free, please see attached screenshot...
Josef
Josef Kucera
Fusion QA
Message 7 of 12
Dear,
I have tried to make a  simply suported like on each end simply suported.
But if I do these I don't get a simulation they just give me a error.
Thanks before hand
Kinds regards
Oona Declerck
Message 8 of 12
josef.kucera
Hi @Anonymous,
you can remove rigid body modes in the study settings, please see attached screenshot:
Josef Kucera
Fusion QA
Message 9 of 12
TMC.Engineering
You could also try this why.  mine is simple in bothe ends wasn't sure how you wanted it.  Constraints only on the edges.  I have not varified with hand calcs but looks resonable.
just a thought
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Message 10 of 12
Dear,
I am sorry but I can't find the general settings.
I have been searching on the internet but I can't find the setting anywhere in fusion 360.
Thanks beforehand
Kinds regards
Oona Declerck
Message 11 of 12
josef.kucera
I wrote it in kind of a hurry.  Sorry about that...
You can access it right from the toolbar:
Josef Kucera
Fusion QA
Message 12 of 12
Thank you everyone if finally worked out in what I wanted to!
Kinds regards
Oona Declerck
