How to make a pattern to cut out of a different sketch?
GudasWorld
GudasWorld
Building a custom pc case. Need to make a (?) to use for cutting out fans. So I am trying to have a sketch that is all the holes for a fan (120mm). 5 holes. Like a template. So I can just copy & paste the fan holes on to my case sketch. Here is my 1st prototype.
I have to redo everything as how I did it all was not good for changing things. I did every hole separately. I am redoing in MM also as I did all my 1st attempts in inches & converting fractions is not a good way to do things.
To clarify I need know what I need to make to make a pattern to copy & paste fan holes on to a panel. Ideally what ever this is it would cut the holes when its pasted.
Thanks for any help!
jhackney1972
I cannot come up with the Automatic Cut, when placing the Template, but it is pretty close.  The template can be placed using a point to point method.  The Template will be thick enough to penetrate the sheet you are cutting the holes in.  I have attached my Template Component for you to examine.
John Hackney, Retired
GudasWorld
Wow! Many thanks! I'm waiting for my MM tape measure to start the new panel. Hopefully this will be the reference I need. I'll probably  want to watch this video a bunch so I hope its not going to be gone. thanks again!
