How to let a Ball follow a Surface?
ManMadeDesaster
ManMadeDesaster
i am currently constructing something and wanted to add a joint so that a Steel Ball follows 3 surfaces while staying in center of a cylinder Perpendicular to the surfaces. I have absolutely no clue how to do that, i have searched for a solution but have not been succesful so i am asking here 😕
(the Pink part moves up and down as well as the blue one)
etfrench
If the balls don't move in relation to the holey part, just use a rigid joint.  You can either use an As-built joint or an offset in a Rigid joint to put the ball in the proper position relative to the hole.
ETFrench
