How to input angle of tangent line?
Click-dragging a line on a circle starts it tangent to the circle.
But then the two input fields seem self-defeating. As soon as you release the click-drag, it assumes you want to end the line segment at exactly where you released it. How to input the angle?
I want exactly 93 deg where the highlighted input field in my screenshot says 93.175 deg. The line also must be tangent to the circle. How to do this?
masa.minohara
Hi @Anonymous,
Thank you for posting! You can specify the angle by hitting Tab key while creating a line, and then add a tangent constraint from the sketch palette.
You can also add sketch dimension and a tangent constraint after drawing rough sketch.
I hope this helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Yes! Thank you. Apparently the sequence of procedure is vital.
