- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm planning to model a large assembly. Instead of having parameters scattered over multiple sub-assembly models (files) its been recommended that I keep on 'master' parameters file (which contains only parameters) and 'import' AND LINK those parameters into sub-assembly model files. The goal is that if a main design parameter changes in the master file, any sub-assembly whose design relies on that parameter gets updated automatically (or at least after a refresh).
The 'master' parameters file only has the root level component, no other components under it and presently contains several dozen user parameters.
So far, after hours of trials and only errors, I've been unable to import the parameters in the master file into another file (e.g. a sub-assembly file will depend on the imported parameters).
