HOW TO IMPORT SOLID BODIES
Message 1 of 11
My question ia about a method to insert , import or open a model or solid that was done previously in other software but in the design I am working at
When I use the Open command to look for an existing model it is opened in a New design and not in the one I am working with.
I can do that only with dxf or  mesh files using the Insert command but not solids
Any help over there?
Replies (10)
Message 2 of 11
davebYYPCU
If compatible format,
Insert into current design,
Data Panel and or File Menus,
This may  be a licence restriction for some.
Might help...
Message 3 of 11
TheCADWhisperer
What file type?
What license type?
Message 4 of 11
thanks for your prompt reply. The type of file is .iges that I exported
from Rhinoceros
I am new at Fusion and I am trying to explore Fusion 360, interested in
parametric modeling and CAM procedures
Message 5 of 11
Thanks for your answer, May be, I am using a free trial License
Message 6 of 11
TheCADWhisperer
You should be able to open IGES, do Stitch or repair, save as *.f3d and insert the *..f3d into your design.
Zip and Attach your IGES file here if you can’t figure it out.
Message 7 of 11
HughesTooling
from Rhinoceros
Export as STP files instead and they will come in as solids.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 11
Thanks for the answer, but I am not able to find the option of *.f3d under the comand Insert
There I only find:
Derive, Decal, Canvas,Mesh, SVG, DXF,McMaster and a Manufacturer part, but not *.f3d
Am I wright?
Message 9 of 11
TheCADWhisperer
I am not at my Fusion machine right now, but can’t you simply drag-and-drop from the data panel?
Message 10 of 11
TheCADWhisperer
@Anonymous
Did you figure out how to drag and drop components into your assembly?
Message 11 of 11
Hello
Thanks for your suport
It works perfect using the drag and drop from the data panel
Very many thanks again
