How to Import a drawing to another drawing?
sami_aslamenterprises
Hello Folks, I have been working on a some sub assemblies to which i have to make a drawing
First of all, please try to understand the system which i have been following
1. part modelling
2. assemble the parts into an assembly ( without breaking link)
3. Then assemble the sub assemblies into a main assembly
But the problem is, I made drawing for all the sub assemblies(which can be changed as per the requirement)
Now i can generate main assembly drawing in one drawing but the sub assembly drawing has to be made again
Is there any way in fusion 360 if we can merge my sub assembly drawings into my main assembly drawing(which will change as the version changes)?
g-andresen
1. drawing „main assembly“
2. new drawing from design > options: existing drawing & same sheet or new sheet
günther
Followed the above steps, still not  able to navigate to existing drawing
any tutorial video would be helpful
g-andresen
No existing drawing is to be inserted into another.
 Open an existing drawing and its design file and then follow this procedure:
1. the existing drawing includes the drawing of the main assembly
2. create another drawing (from design) from the main assembly and select these options.
3. create a new base view
4. deactivate the unwanted sub-assemblies
günther
