Can't get the fillet to be lined up on different edges due to disparate angles? Is there a simple way to do this without creating a ton of sketches and lofts?
I do not see where you are placing the Fillet on the supplied model. Please take a larger screen capture and indicate where the fillet is supposed to be.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
This was the specific edge in the screenshot but it will be applied throughout the model.
Loft will work. The only problem is determining the sketch planes.
ETFrench
