how to graduate scale on knob?
8 REPLIES 8
Message 1 of 9
damien.darhk
968 Views, 8 Replies
Hello, I'm trying to design a knob(that in my case is a simple cylinder) with  a marked scale, with a mark and the degrees number ever X degrees on the circumference.
Anybody know a fast way to do that? I cannot figure it out.
8 REPLIES 8
Message 2 of 9
davebYYPCU
in reply to: damien.darhk
These markings are on the flat face or cylinder wall?
Either way, make one and use circular pattern.
Make one with a sketch line and
a cylinder pipe as a cut is one way.
Might help...
Message 3 of 9
damien.darhk
in reply to: davebYYPCU
On the cylinder wall
Message 4 of 9
wmhazzard
Here is one way to do it, with a circular pattern of faces. These are every 5 degrees.
Message 5 of 9
damien.darhk
in reply to: wmhazzard
Ok. I got it. I have only one question: how can I add number next to the marks ?
Message 6 of 9
One at a time for the text.
Message 7 of 9
wmhazzard
Text is tedious but it is a little better using sheet metal and putting the text in a flattened sheet matching the dial and doing an extrude cut then combine. I only did to 75 but you could take it from there.
Message 8 of 9
damien.darhk
I'm trying to make a doble scale one for side. but when I try to joint it with the cylinder it sayt that the joint already exist and if I continue it broke the joint with the other scale. What am I missing?
Message 9 of 9
wmhazzard
I don't know, can you attach an f3d file of your model?
