HOW TO GIVE ANGLE BETWEEN LINE IN FUSION 360
sHubamyadav016
Message 1 of 15
sHubamyadav016
[ The subject
Replies (14)
Message 2 of 15
mufuo
Could you try the code below?
import adsk.core, adsk.fusion, traceback, math
def create_and_extrude_panel():
    app = adsk.core.Application.get()
    design = adsk.fusion.Design.cast(app.activeProduct)
    if not design:
        ui.messageBox('It is not supported in the current workspace. Please change to the MODEL workspace and try again.')
        return
    # Create a new component for the panel.
    root_comp = design.rootComponent
    new_comp = root_comp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
    panel_comp = new_comp.component
    # Create a new sketch for the panel profile.
    sketches = panel_comp.sketches
    xy_plane = panel_comp.xYConstructionPlane
    panel_sketch = sketches.add(xy_plane)
    # Define the corners of the panel profile.
    corner1 = adsk.core.Point3D.create(0, 0, 0)
    corner2 = adsk.core.Point3D.create(0, 1588, 0)
    corner3 = adsk.core.Point3D.create(200, 1717, 0)
    corner4 = adsk.core.Point3D.create(200, 0, 0)
    # Create lines connecting the corners to form the panel profile.
    lines = panel_sketch.sketchCurves.sketchLines
    # Define the angles between the lines.
    angle1 = 123
    angle2 = 57
    # Create the lines with the specified angles.
    line1 = lines.addByTwoPoints(corner1, corner2, angle1)
    line2 = lines.addByTwoPoints(corner2, corner3, angle2)
    line3 = lines.addByTwoPoints(corner3, corner4)
    line4 = lines.addByTwoPoints(corner4, corner1)
    # Extrude the panel profile to create a solid body.
    bodies = panel_comp.bRepBodies
    panel_body = bodies.add(panel_sketch, adsk.fusion.FeatureOperation.NewBody)
    return panel_comp
# Call the function to create and extrude the panel.
panel_comp = create_and_extrude_panel()
Mustafa Furkan Özel
Project - R&D Manager
LinkedIn
Message 3 of 15
sHubamyadav016
File "C:/Users/RND7/Desktop/CHECKING/Untitled-1.py", line 35, in create_and_extrude_panel
TypeError: SketchLines.addByTwoPoints() takes 3 positional arguments but 4 were given
i am getting error
Message 4 of 15
sHubamyadav016
please see the drwing please tell me the project how can i make profile with drawing
Message 5 of 15
mufuo
I think it will work this time.
    if not design:
        return
    angle1 = 123
    angle2 = 57
    line1 = lines.addByTwoPoints(corner1, corner2)
    line2 = lines.addByTwoPoints(corner2, corner3)
    return panel_comp
Mustafa Furkan Özel
LinkedIn
Message 6 of 15
sHubamyadav016
NO It is not working please once see the drawing  please help me how to draw these angles please sir
Message 7 of 15
sHubamyadav016
NO IT IS NOT WORKING THIS TIME ALSO
Message 8 of 15
mufuo
Do you want a code or is the drawing file enough?
Mustafa Furkan Özel
LinkedIn
Message 9 of 15
sHubamyadav016
I WANT CODE PLEASE HELP ME
Message 10 of 15
sHubamyadav016
I want code
Message 11 of 15
mufuo
Finally, I created 2 more codes. If one of them does not work, there is nothing else I can do.
Option 1
    if not design:
        return
    angle1 = math.radians(123)
    angle2 = math.radians(57)
    return panel_comp
Option 2
    if not design:
        return
    line3 = lines.addByTwoPoints(corner3, corner4, angle1)
    line4 = lines.addByTwoPoints(corner4, corner1, angle2)
    panel_body = bodies.add(panel_sketch, adsk.fusion.FeatureOperation.NewBody, 50, adsk.fusion.BodyAppearance.Smooth)
    return panel_comp
Mustafa Furkan Özel
LinkedIn
Message 12 of 15
sHubamyadav016
Bro both of your code is not working
Message 13 of 15
mufuo
I made one last attempt not to leave you alone.
def create_and_extrude_shape():
    if not design:
        return
    # Create a new component for the shape.
    shape_comp = new_comp.component
    # Create a new sketch for the shape profile.
    sketches = shape_comp.sketches
    xy_plane = shape_comp.xYConstructionPlane
    shape_sketch = sketches.add(xy_plane)
    # Define the corners of the shape profile.
    # Create lines connecting the corners to form the shape profile.
    lines = shape_sketch.sketchCurves.sketchLines
    line1 = lines.addByTwoPoints(corner1, corner2, 123)
    line2 = lines.addByTwoPoints(corner2, corner3, 57)
    line3 = lines.addByTwoPoints(corner3, corner4, 123)
    line4 = lines.addByTwoPoints(corner4, corner1, 57)
    # Extrude the shape profile to create a solid body.
    bodies = shape_comp.bRepBodies
    shape_body = bodies.add(shape_sketch, adsk.fusion.FeatureOperation.NewBody, 50, adsk.fusion.BodyAppearance.Smooth)
    return shape_comp
# Call the function to create and extrude the shape.
shape_comp = create_and_extrude_shape()
Mustafa Furkan Özel
LinkedIn
Message 14 of 15
sHubamyadav016
you are doing same error in every program
 you are defining add two points and also also giving angle it is acceptabel than your giving me precious time
Message 15 of 15
sHubamyadav016
Sir you really helped me and gave me your precious time but you did not see the drawing attached with my question and in every program only one error and same error you can not define add by two point with three values I sent you errot but you are repeation same error in every response .
thank you
