How to get an unfishnet split with an extruded form ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
HI,
I am using an extruded form to split the cube.
That works fine, but I get a fishnet on the cut.
How can I get a neat cut, or eventually, how can I erase the edges of the fishnet, after splitting.
If I don't weld some vertices of the extruded form, the cut is neat.
If I merge edges or weld vertices, the cut has a lot of edges, and I don't want such result.
An inspection with curvature map analysis don't show any discontinuity of the cutting surface.
So what is wrong for me ?
Thanks you for your help.
