- Mute
- Permalink
- Report
Hi everyone and thank you for your help.
I am busy with the design for a box for my diode laser/engraver and learning more and more as I go along. I managed to design the front, back, left and right panels. After this I extruded all of them in order for me to use the finger joint add-in. It can only joint bodies and not sketches.
I need to make/get sketches from all 4 panels in order to make the toolpaths that I use in my CNC's software. These I need to save/export as DXF files. I know that it is possible to save sketches as DXF but not bodies. When I right-click on a body, there is not option to create a text from the geometry of the bodies.
I am sure that it is possible but I don't know what to search/look for?
Thank you very much so long for your advice.
