How to Fold 20mm Edge Without Merging in Multi-Angle Cladding Panel?
arthurQ4G75
arthurQ4G75
Hello, Fusion 360 experts,
I am working on a cladding panel with multiple angles, and I need to fold a 20mm edge on one side at a corner. However, the issue is:
  1. The fold must align precisely with the "3mm Left Plane".
  2. It should not merge with the rest of the panel after folding.
  3. I need a technique that ensures accurate alignment while maintaining the fold's integrity.
I have attached my Fusion 360 file for reference. Any suggestions on the best workflow, tools, or constraints to achieve this would be greatly appreciated.
Thanks in advance!
Warmingup1953
No file attached to your post.
arthurQ4G75
Apology, see attached file
johnsonshiue
Hi! Many thanks for sharing the design! I am sorry that I am having trouble following your requirements. Please share an image showing the exact Sheet Metal geometry you would like to create on the attached model.
Thanks again!
Software Test Engineer
kacper.suchomski
Hi
Does measuring the angle inside the operation solve the problem?
(view in My Videos)
Kacper Suchomski
arthurQ4G75
Sir, Thank you for taking the time to answer the problem. The issue was partially solved by showing how to align the folding to the plane. However, these five sides (see attached screenshots) need to fold inward, all coinciding with the same plane (3mm left plane).
kacper.suchomski
Fusion ma bardzo ograniczone narzędzia do modelowania blach. Myślę, że bardziej efektywne byłoby modelowanie go w trybie powierzchniowym.
Tutaj możesz zobaczyć jak wygląda modelowanie powierzchni arkuszy (w innym programie, ale filozofia jest ta sama):
https://youtu.be/JfWM1INu02M?feature=shared
Kacper Suchomski
