How to flatten curved bodies for 2D laser
zdenek.hajn
Message 1 of 10
zdenek.hajn
is there any way to make curved bodies flat? I watched many videos, read many forums, but I cant make right files. My supplier need STEP files for 2D laser and information about bending final parts...oplechovani v4.pnglimec podvozku v10.png
Accepted solutions (3)
Replies (9)
Message 2 of 10
g-andresen
some things (thickness) are wrong with the designs and sheet metal rule.
günther
Message 3 of 10
zdenek.hajn
It should be Alluminium 3mm... Can I fix it?
Message 4 of 10
g-andresen
When converting imported parts, the existing thickness is used as the basis for the rule.
You have to make sure that the parts have the desired thickness.
Also, a flat pattern can only be generated for one part in a sheet metal component.
günther
Message 5 of 10
TheCADWhisperer
What is the source of the original geometry?
Message 6 of 10
zdenek.hajn
Will try to do it again... This is first sketch from which I make all bodies...
Message 7 of 10
TheCADWhisperer
It does not appear to be fully defined (no dimensions and blue rather than black).
Do you have Capture Design History turned on?
With Sheet Metal - you don't need double lines to define Thickness - Fusion will do that for you.
Message 8 of 10
HughesTooling
You need to be careful offsetting an ellipse. If you end up with 2 ellipses the wall section will not be constant. If you use the offset tool and pick near a quadrant the offset will be an ellipse and the distance is not constant but it you select at a point 45° between the quadrants the offset will be a spline and you'll get a constant thickness.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 10
zdenek.hajn
Thanks for help, will do it better...
Message 10 of 10
zdenek.hajn
Thanks for help, will do it again and better
