How to fix this issue?
stanislav_shevchenko
Message 1 of 10
Im newbie in fusion 360. Stuck on this. On some step happened this. Rounded corner on top and bottom part is different. Only one corner, others is fine. I need make bottom corner smaller.
Monosnap Autodesk Fusion 360 (Personal - Not for Commercial Use) 2024-01-31 12-47-26.png
Replies (9)
Message 2 of 10
g-andresen
please share the file
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 10
jhackney1972
I believe you have a STEP file which you want to change the corner radius.  Use the Press Pull command and enter the value you want.
John Hackney, Retired
Message 4 of 10
Press Pull not actually help. I'm attach project to post.
Message 5 of 10
TheCADWhisperer
Can you simply Delete the faces and enter new Fillets?
Having said that, I see a lot more issues that if this were my work I would simply recreate proper geometry from scratch.
Message 6 of 10
I don't know how do that and not destroy entire model.
Message 7 of 10
TheCADWhisperer
Did you try it?
Attach your "destroyed" model here.
Message 8 of 10
SaeedHamza
Here is the reason you're having this issue, you've used the Offset Face tool (shown in the screenshot below in the timeline) and selected that corner alone without the rest of the corners.
Saeed Hamza
Message 9 of 10
g-andresen
one workaround: "delete fillets" and recreate them in the desired size
günther
Message 10 of 10
SaeedHamza
guys, there is no need for a workaround when the core issue is a misselection, that when fixed the whole thing is working proberly ...
I've noticed that some are suggesting recreating the whole thing when there is no need to!
Saeed Hamza
