How to find sketch errors?
Message 1 of 27
Hi guys.  Routinely, during my design process,  I remove/edit geometry that is referenced by downstream sketch constraints.  Thus, these downstream constraints fail.  Solidworks calls these "dangling" constraints and it has a tool to view all the sketch constraints within a sketch.  Over-constrained items show up red, dangling show up yellow.
Is there a tool in Fusion to view my sketch constraints?  It frustrating to be told there is an error, but no mechanism to determine what the error is.  Is there a tool like this that I'm missing?  Attached is a pic of a sketch that has an error - no idea what it is.
Walt
Replies (26)
Message 21 of 27
TheCADWhisperer
@TrippyLighting wrote:
 A different attitude would also likely be beneficial!
@Anonymous
You must become a True Believer. (see defn #2)
Message 22 of 27
bradyDW3ZC
Is this issue still not resolved? I try to be understanding of bugs and frustrating abnormalities in Fusion since A) SolidWorks isn't perfect either, and B) Fusion has a much more accessible cost. However, I came here trying to diagnose a mysterious sketch error, assuming there was a tool for such a purpose that I simply couldn't find, and discover it simply doesn't exist. A downstream sketch turned yellow in my timeline after an upstream change and the only information I have to go on is "compute failed". I'm sure my workflow could be improved but sketch errors are common in the real world. How is it acceptable to not have a system for finding them? A simple highlight? Anything? How could this not be a priority?
Message 23 of 27
TheCADWhisperer
@bradyDW3ZC
There is a "sort of" tool, but I forget how to access it.
I might be motivated to find the tool if I had a file with which to experiment.
Message 24 of 27
bradyDW3ZC
Thanks for the reply! I decided to just redraw the sketch but I thought I should still voice the issue since the Fusion rep said it was a low priority for them and I don't think it should be 🙂
Message 25 of 27
TheCADWhisperer
Dang it all, now I can't find the reference to secret Text Command to check the sketch.
Hopefully someone who knows the secret code will come along and reveal.
Message 26 of 27
djlunty
@TheCADWhisperer
@bradyDW3ZC
Is the text command you are looking for
Sketch.ShowUnderconstrained
Doug
Message 27 of 27
pizzi.joe
Observer
Observer
Seven YEARS and still not resolved!
