Lost bodies in the broweser for Sculpt mode - BUG
I have several T-Spline bodies. After finishing the form they appear as solid bodies. Then I can edit them, they are shown as T-Spline bodies again. Still that all is perfect.
But!
Then I chose "Do not capture Design History" mode. I did not find what I searched for in this mode and decided to return back using "Undo". All history returns. Ok.
Then I again went to edit T-Spline mode and could not see the list of bodies anymore. I can select individual bodies and the name of body appears in the right-bottom corner. But the browser does not show bodies at all.
Save-Close-Reopen the design fixes that (bodies are again visible in the browser in Edit T-Spline mode).
innovatenate
Autodesk Support
Autodesk Support
Thank you for reporting and for the screencast. This is easily reproducible from scratch in latest build. I have escalated a report (internal ID FUS-30338). I'll circle back as I find out more information. Let me know if you have any quesitons!
Thank you!
Nathan Chandler
Principal Specialist
