How to fillet between dynamically toggled bodies
Umbriel
Umbriel
EDIT: Posted in the wrong place, feel free to remove
[Post moved to Fusion Design forum by CGBenner 2/11/2025]
Hi, I have a 3x3 grid showing different shapes controlled from my Configuration table.
But I can't figure out how to apply a fillet between the dynamic 3x3 grid and the main body. Normally I'd Combine/Boundary Fill everything together, but since its dynamic it breaks the fillet. I also tried using Rule Fillet but doesn't seem to work well with extruded bodies?
You can see in the video below as I click through the configurations how the raised bumps in the grid toggle on and off in the Browser. I like this setup of toggling the shapes, but maybe there is a better way to do this and still be fillet compatible?
I also attached the working file.
(view in My Videos)
Thank you
gautham_kattethota
Hi @Umbriel , features like fillets and chamfers track selected edges.  As you switch between configurations and different raised bumps get activated, they have different edges.
You can however use a suppression matrix and create fillet for the bumps in a configuration, and suppress this fillet when you switch to other configurations, where you would repeat the same process.
Gautham
Gautham Kattethota
Software Development
CGBenner
@Umbriel
Hi, do you still need help with this question?
Chris Benner
Umbriel
Hi, the duplicate of this question has an accepted solution, no help needed thank you!
https://forums.autodesk.com/t5/fusion-design-validate-document/how-to-fillet-between-dynamically-tog...
