I have 2 solids: a cylinder and a Rectangular bar touching the cylinder along the straight edge. I wish to fillet between them but it seems the fillet command works on 1 part only. Any ideas?
Solved by g-andresen. Go to Solution.
Solved by schneik-adsk. Go to Solution.
Parts ? Do you mean bodies, or components ?
Use "Modify->Combine" with the "Join" option to make one body out of it. Then you can fillet the interface.
I meant components. We are going to weld two parts together. I'd like to model that:
Autodesk Inventor Professional has a weldments environment.
Perhapses if the user had posted to the Inventor forum this would have been helpful.
I attached a video on one way to model a bead using a base feature and combine booleans.
Wow, that's great!
A simple solution leaving the two components intact and showing the weld as a separate body.
Thank you very much.
Paul
