How to fill odd shaped gap?
Message 1 of 28
Hello guys,
I am new to Fusion 360. And I was wondering how to fill in the space that I have circled? I figured it is a basic task, but I am having a little trouble.
thanks
Replies (27)
Message 2 of 28
jeff_strater
Hi @Anonymous,
This is relatively straightforward.  It's basically just deleting all the faces at once.  In the screencast below, I first use "Find Features" to identify the fillet (just to make deleting it easier, you don't have to do it this way).  Then, I just selected the remaining faces of the cutout, and used "Delete" to get rid of them.  In Fusion, in the Model workspace, deleting a face will "heal" the body:
Hope this helps,
Jeff
Jeff Strater
Engineering Director
Message 3 of 28
Hey Jeff,
I have a few more revisions that would really help me out.I don't want to take advantage of your time, but Can I send you some stuff and you send me the file back?
thanks
Miller
Message 4 of 28
I did it!
thanks jeff
Message 5 of 28
jeff_strater
Hi @Anonymous,
So are you good now?  Do you need more help?
Jeff
Jeff Strater
Message 6 of 28
no!! This is awesome work man. If you know of any good online classes I would appreciate it. But check this out. So, I want to change the name of the product from BōT RōP to MOOR LINE® with this font. How do you delete BōT RōP and Put moor Line like the font you see in the attachment?
thanks
Miller
Message 7 of 28
jeff_strater
Here is how you can do that.  Basically, the removal is similar - select the right faces and delete them.
To add the new logo, create a sketch on the face.  Use the sketch Text command to add the new logo (I'll let you search for the font you want).  Then, extrude the new text to whatever height you want.
Jeff
Jeff Strater
Message 8 of 28
Hey Jeff,
I've done everything but ®. Fusion wanted to turn it into a different character. should I just do a regular r and put a circle around it manually?
thanks again!
Miller
Message 9 of 28
jeff_strater
Hmm... It should work.  You might try a different font, just for that one character.  Although I tried two, and found the same problem (it took me a while to get that character even added to the text).  This looks like a bug, and I'll report it.  In the meantime, yes, I guess the workaround is to add a small R and a circle...
Thanks for letting me know.
Jeff
Jeff Strater
Message 10 of 28
I think there is another Glitch in the matrix. I want to use the font serpentine bold and I found the text in the text box pull down menu but it turns out to be a different text in fusion. Here is what it should look like and here is what fusion is putting out. Fusion's serpentine bold is in the blue. The other attachment is what it should look like.
thanks
Miller
Message 11 of 28
Hey Jeff,
Can you help me with a text situation again. Every time I try to add text, it wants to write on one of the planes instead of the actual piece.
Message 12 of 28
laughingcreek
The "text" command, in the sketch tools, places text in a sketch.  Only in a sketch.
One thing to realize is this.  If there isn't a sketch currently active (in edit mode), then selecting ANY of the sketch commands will actual run 2 commands.  It runs "create new sketch" first.  The first click in this situation will actually serve to select the plane you want to start that new sketch on.  I suspect your picking one of the origin plans by accident here because your not starting with an active sketch.
I always suggest either creating a new sketch, or selecting "edit" for an existing sketch BEFORE selecting any other sketch tools for this reason.
Does this sound like what's happening to you?
Message 13 of 28
I still can't seem to get it off the plane. Do you have a 1,2,3 steps I can go through?
thanks
Miller
CAD Piece:
http://a360.co/2z3lOVf
Message 14 of 28
laughingcreek
maybe this helps
Message 15 of 28
I did it! Man this program is so technical...It took me awhile because I wasn't selecting the text before I extruded and then I didn't select the object before extruding. I'm new to the program and I am learning on the fly. if you have any classes I can take let me know.
thanks laughing
Miller
Message 16 of 28
Hey guys,
I am stumped again. Can you take a look at the screenshot below.
Miller
CAD PIece:
http://a360.co/2itXKR2
Message 17 of 28
laughingcreek
I couldn't access your file. Could you export and attach it instead?  You can export from the file menu-
Message 18 of 28
jasonhomrighaus
To fix that depends on how you created the sheet metal flange.  if you came off of a drawing line you could go back and edit the drawing and that should fix it, if your not in sheet metal then create a construction Plane in the center, split the body then push pull an equal amount of both halves then push together and combine.  can you post your model if your having issues.
Message 19 of 28
Hey Jason,
you can't do a little video of that can you? I'm looking to get all holes at 12.7 mm which is half an inch. The bend with the hole is seeming to do things funky as well?? Sorry for the inconvenience.
thanks
Miller
Message 20 of 28
jasonhomrighaus
Here you go, one for the change in dimensions and another on drilling the holes.  Let me know if there is anything else I can help you with.
