how to fill in a wire frame ?
Hey guys so i am new to posting here but read the forum frequently. currently i am stuck on trying to fill in a wire frame 3d sketch as i cannot create the shape with a tapered extrude it seems to make it conical and i don't want that. i have attached a picture of the wire frame sketch. is there a way to fill this sketch in i am trying to make a press die for thin aluminum. any help would be greatly appreciated.
davebYYPCU
Provided the front and back sketches have profiles, they should Loft without drama.
Might help....
TheCADWhisperer
Can you File >Export and then Attach your *.f3d file here?
If the data is proprietary, can you create a dummy example file with just that sketch(es) in question?
If Loft does not work, then Patch and Stitch certainly will.
(It appears to me from the image that you have some 2D geometry.)
 (Your computer probably has a screen Snipping app that you can use for high quality screen captures rather than your camera phone.)
(Are you sure that you don’t want those curves to be tangent to the angled lines.
thank you patch and loft were what i needed. still very new to fusion and overlook the obvious.
