How to fill in a Sweep in the Patch menu
ianhughes7UFVF
ianhughes7UFVF
Hi
For my project, I have had to use a sweep to create a tube of sorts along a specific path.
The problem is its hollow.
How would I make the insides solid?
This will be 3d printed in due course so needs to be solid in fusion.
As always, any help will be great.
Kind Regards
Ian
jeff_strater
I guess the first question is:  If you want these to be solid, why not just use the Solid Sweep command instead?  Just delete the surface sweep and re-create those features as solid sweeps.
If there is some reason why this won't work, then use the Boundary Patch command to create a surface on the open ends of the surface bodies, and stitch them all together, this will automatically create a solid, if the resulting surface body is fully closed.
Jeff Strater
Engineering Director
ianhughes7UFVF
Hi
Thanks for that. I didn't realize there was a solid sweep command. I will have to have another look.
Is that in the patch menu or model menu?
Kind Regards
Ian
jeff_strater
yes, in the model menu.  I have the "new UI" preview enabled, but the icon is the same:
Jeff Strater
