- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am struggling to accomplish the extrusion of a cylinder from a cylindrical surface, add some feature to the cylinder (see upper left corner) and afterwards make those into a revolved circular pattern along the curved surface.
When I try to draw the circle and project it onto the curved surface, the resulting circle cannot be extruded or pushed/pulled and I guess its not a real circular cylinder anymore.
When I use split surface, the result cannot be extruded but it can be pushed/pulled but gains in size as its extruded outwards and the origin shape is not a real circle anymore.
Furthermore I would like to have a resulting cylinder revolved as a circular pattern along the curved surface. But neither projection nor split surface allowes the result to use circular pattern.
I tested with "plane at angle" but it would have to be a new plane for every cylinder. It seems overly complicated that way plus I was unable to align the cylinders correctly.
Hopefully you can help me with a solution.
Thanks for you help
