How to export rendering with Transparent background successfully.
Adrian.Mangan
Adrian.Mangan
Hi All, First time posting here but have been using Fusion for couple of years, I am creating some components for a company and I am having difficulty exporting rendering with transparent background, in the past I have been able to do this but does not seem to be working now.
Any advice welcome.
LeonardoBN
Hi @Adrian.Mangan.
Do you checked Groud Plane? Try disabling it.
Edit:
I usually don't use Local Render, but I found out other topics about the Transparency on Local, and it is related to Ground Plane.
The image will still have a background in the Render Gallery, but the saved image will have the transparency.
Leonardo Brunelli do Nascimento
Chemical Engineer
SaeedHamza
You can do it after you render from here
Saeed Hamza
Adrian.Mangan
thanks @LeonardoBN I have disabled the ground plane after a little googling, but gonna try work with it now again.
Adrian.Mangan
Let me try this @SaeedHamza , thanks for the input, I have seen this dropdown before but not in the case I have now, what options did you choose for rendering if you don't mind me asking.
SaeedHamza
If I remember correctly, it doesn't appear when you render locally, only by cloud render
Saeed Hamza
