How to export a flat pattern with embossed text to .dxf
adam
Message 1 of 12
adam
I have a laser cut and folded panel with laser embossed text, I need to export this to send to the laser cutting company, but when I export to .dxf, the text layer is not included.
How do I do this?
I'm sure there must be a simple way, but I'm struggling to find it 😕
Accepted solutions (3)
Replies (11)
Message 2 of 12
hamid.sh.
Firstly, use the surface with embossed text when selecting Stationary Face for creating the Flat Pattern. Then create a Drawing from your flat pattern. In drawing workspace use 1:1 scale and disable the Title Block. Have Bend Extents option on for bend lines:
Finally, Export Sheet as DXF in Drawing workspace.
Hamid
Message 3 of 12
adam
@hamid.sh.- thank you for this neat workaround!  😀
Message 4 of 12
adam
Looking at this again, the .dxf generated by the drawing has various undesirable properties for laser cutting (such as line widths), is there any other way to do this and get the accurate paths?
Message 5 of 12
g-andresen
1. Unfold
2. Create sketch & project your object into
3. Rightclick sketch (Browser) > save as DXF
günther
Message 6 of 12
hamid.sh.
Then follow @g-andresen 's suggestion:
Or quite similar thing but within Flat Pattern, in case you want to have center bend lines (you should select them for projecting):
Hamid
Message 7 of 12
adam
Thanks for the suggestions, having tried them now, I can confirm that I'm getting the best result from this workflow:
1. Open the flat pattern
2. Right click the surface and 'create sketch'
3. In the sketch, project the surface, (including any 'islands' within the letters) and the bend lines.
4. Finish the sketch
5. Right click the new sketch in the browser and save it as a dxf
6. Use a separate 2D CAD program to move the items manually onto layers as required.
This gave me nice clean paths and also saved the embossed text as outlines (so no issues with missing fonts later).
Thanks again to @guenther.andresen and @hamid.sh. for this solution
adam
in reply to: adam
2 weeks ago
Message 8 of 12
robertX3LQA
Does this require some particular subscription of Fusion360? There is no export as DXF option in the menu for me.
Robert
Message 9 of 12
TheCADWhisperer
@robertX3LQA
Are you currently in an active sketch?
Or at least a screenshot of what you see?
Message 10 of 12
robertX3LQA
I can unfortunately not share the model, but here is a screenshot of the menu items available to me:
Robert
Message 11 of 12
laughingcreek
right click on sketch from the browser tree. you don't have to be in an active sketch
Message 12 of 12
robertX3LQA
Ah, in the browser. Thank you! I was clicking in the Design History, where there is no such option. Thank you!
