how to emboss, or deboss, grooves into a lofted curved surface?
tdainsworth
Message 1 of 8
tdainsworth
Per this other thread, apparently emboss (or deboss like I want) does not work on double-curved surfaces, only simple curves which can be unfolded w/o distortion; it directly states the clue that a curved surface will not work is that you cannot select it, just like my situation where I cannot select my curved face.
I'm trying to replicate this model picture, thus I want to get the grooves into curved surface of my body. I have an offset plane with the 30 grooves that I want, but I can't figure a solution to do the deboss into my curved body. Any suggestions would be very appreciated!
modelmodelsketched grooves over bodysketched grooves over bodyoffset sketch plane over curved bodyoffset sketch plane over curved body
Replies (7)
Message 2 of 8
aliobidi
Hi ,
try extrude "start from object " command.. or attach your file
Message 3 of 8
jeff_strater
@aliobidi has the correct answer here.  But, just FYI, Emboss to doubly-curved surfaces is in progress and, while I can't say when this functionality will appear in Fusion, it is on the way.
Jeff Strater
Engineering Director
Message 4 of 8
laughingcreek
@jeff_strater -once the enhanced deboss is available, would it even be the right tool here?  the grooves on the object are straight,  wouldnt debossing straight lines onto a curved surface produce a curved groove?
maybe geometric pattern would be better here (for those with access)
Message 5 of 8
matthewrjacobs
I 've found that extrude/start from object is rather picky on where it will work.   if the advice @aliobidi gave doesn't work,  you can try creating a zero offset surface and use that as your starting object, sometimes that does the trick.
Message 6 of 8
jeff_strater
@laughingcreek - I'm not sure what the result will be.  I think the hope is that the grooves would be straight on this model, but we'll have to see the results to be sure.
Jeff Strater
Message 7 of 8
tdainsworth
ok, this mostly works! I had not Extruded from an Object before. I need to work through some issues cuz it throws an error when I try to Cut 1mm deep at the very edges since that goes beyond the body which does not make sense to me cuz I am actually doing a Cut, but in general I think this solution is going to give me what I need! Thank you!
(yeahhhh you might notice it's a new sketch, I forgot to save all of last night's work, oops, but all good! making progress again!)
Extrude cut on an ObjectExtrude cut on an Object
Message 8 of 8
tdainsworth
curved grooves around the body uniformly 1mm deep is exactly what I wanted
