How to edit a table
How to edit a table
jcsantilli
How to edit a table
jcsantilli
I'm trying to edit a table on a drawing but when I click on Insert a Row Below, inserts the new row on the right side of the table. Can anybody tell me what is going on?
lucasliraAU
Thanks for reaching out to us on the forums!
To perform the action on your table you must keep the selected cell before the addition feature.
To do this and just keep the cursor on the cell - Column or Line and click add in the menu.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Ricky.bingham
Hey @lucasliraAU,
I did this but the rows are still being generated to the left of the existing table. Is there some vertical limit of 5 rows that i can adjust?
jhackney1972
Adding Rows manually only works in Custom Tables.  You have the words Parts List at the top of your table but I am guessing this is a Custom Table.  Parts List will only expand as the number of component increase.  To add Rows to your Custom Table follow what the process I use in the Screencast.  Remember, if you want more columned rows, highlight row 2 and then select the add rows.  If you want non-columned rows, highlight row 1 and then select add rows.
John Hackney, Retired
