How to edit a body without a sketch?
sentfromjami
sentfromjami
Community Visitor
Community Visitor
Hi folks,
I'm trying to design a headband that will have varying lengths of the "rays" or points. However, when I go to pattern the points around the edge of the headband it only copies bodies, no sketches for those bodies. I have found the easiest way to edit the length via the sketch, but there very well could be a better way as I am very new to this. Thank you in advance!
TheCADWhisperer
@sentfromjami
etfrench
Change the pattern's path so that each point extends past the inside of the hoop. Use the split body command to remove the inner excess.  If you draw your path right, you'll have different lengths for the points.
ETFrench
