How to duplicate a sketchup rendering?
Message 1 of 10
Hello folks, I drew this table in sketchup and now I want to recreate it in fusion. I can figure out how to do the majority of the base but not sure how to do the top portion of the trestle?
Can a person use the revolve tool on a square so I can recreate the top portion of this trestle base?
I am attaching a picture of the sketchup rendering.
Thank you
Replies (9)
Message 2 of 10
TrippyLighting
If you can share your design so we've got something to work with that Ould be helpful. For you 😉
You may ant to look at the sweep tool.
Message 3 of 10
davebYYPCU
Easier to use the Loft Tool,
adjust the curve result with the Direction arrows.
Might help....
Message 4 of 10
Thank you! I used the loft tool but not sure how to adjust with direction arrows?? 🙂
Jay
Message 5 of 10
PhilProcarioJr
@Anonymous
All you need to do is create a sketch with the square shape the size you need, then create a profile sketch and sweep it around the square. If you can not figure it out with my file let me know and I will add a screencast.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 6 of 10
WOW!! thats what I need!!! Thank you! Will it be possible to send me a screen cast? I am sorry to bother you, I seem to learn much better from watching something being done as I am so new to fusion, but I really like it so far!!
Thank again!
Jay
Message 7 of 10
PhilProcarioJr
 @jayshockey221
One thing I might add is make sure you constrain and dimension your sketch....I didn't have time to do that here.
https://knowledge.autodesk.com/community/screencast/7d22c67d-f0b4-4c86-8d08-a6af5024e374
Phil Procario Jr.
Message 8 of 10
That was AMAZING! Thank you!!
Jay
Message 9 of 10
chrisplyler
There are many ways to skin a cat..
1. Lofting between horizontal profiles...
2. Extruding/intersecting two vertical profiles...
3. Sweeping a perimeter around a square path then deleting the hole...
Message 10 of 10
etfrench
You left out circular pattern Smiley Happy
ETFrench
