How to draw curved coil spring in fusion 360?
Message 1 of 9
I having difficulty in modelling a curved coil spring in fusion 360. Could anyone be of any help.
Replies (8)
Message 2 of 9
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Are you trying to create a custom profile and sweep it along a helix path (such as a coil)? I did want to note - we also have a built in coil tool under the Create menu. In any case, the screencast below should document what you are looking for. Pretty much, we project the path of the coil and use the Plane along path command from the Construct menu to create the custom shape.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Message 3 of 9
JDMather
Spiral flat profile spring like that in a tape measure or wind up toy?
Circular "helix" garter spring?
Can you link to image of something similar to your design intent?
Message 4 of 9
I want this this type to be made.
Message 5 of 9
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
It is going to be tough to create a coil along a curved axis using the method I posted above. @dinocoglitore came up with a pretty neat API found here. You may want to check that out and see how you can adapt that for your needs. Otherwise, this will need to be very manually created using the techniques that he highlights in his post here.
James Youmatz
Message 6 of 9
dinocoglitore
Hi James.Youmatz, thank you for have mentioned me in your post.
Hi @guptaabinash468, I hope that the link posted by James.Youmatz could be useful for you.
I think that this article is an advanced deepening of a previous article.
I suggest you to read the article posted here. But I thing is more useful for you to read my first article about empirical construction of helix: http://autode.sk/2mp9MLD
You can find an example of application in the Fusion gallery: https://gallery.autodesk.com/fusion360/projects/helix-1
It seems real similar to what are looking for.
Don’t’ forget that the script I wrote was with a didactic point of view.
Dino
Message 7 of 9
Hi, how do you draw the 3d splines in space like that? What is that under? Thanks!
Message 8 of 9
dinocoglitore
Hi wtbuser, thanks for the question, but I don't understand your request. All I've done is explained in the articles which references you can find int the post. Can you be more explicit in your question and add some pictures ?
Dino
Message 9 of 9
TrippyLighting
You may want to try this .
