how to disable giant green ball when rotating?
JustinHoMi
JustinHoMi
After the latest update, there's a giant green ball obscuring the model when I rotate it. How do I disable this? It makes it difficult to see the part. I find myself having to re-rotate the part multiple times to get the view I want.
Justin
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion 360 community and thanks for posting your question! I'm not familiar with that green ball.
Does it appear when using the Move command or when orbiting the workspace?
Can you check the Graphics Diagnostics command from the help (?) menu?
Can you use the Copy to Clipboard command and paste the results in a reply?
Does checking the "Limit all effects... " option help?
Looking forward to your reply...
Nathan Chandler
Principal Specialist
JustinHoMi
The ball went away on it's own. I'm not sure if it happened after I closed and reopened the app, or after an update. The ball is now small and non-intrusive.
