How to dimension threads in Drawing?
niels.bosmans4WT2M
niels.bosmans4WT2M
How should I dimension threads in a Drawing? The only option I found now is by manually typing e.g. M8 x 1.0. Is there no option that automatically takes the thread that was dimensioned in the Model?
I have added a screen shot of the result I would like to obtain. I have now added this dimension using the Leader function.
subashchandrabose2003
can you please attach a screenshot for better understating
subash chandra bose.A
niels.bosmans4WT2M
I have added a screenshot to the first post. Thank you for the comment.
Marco.Takx
Hi @niels.bosmans4WT2M,
At the moment this isn't possible.
Please Vote the Idea on the Fusion 360 Ideastation
Request-to-bring-retrieve-dimensions-into-Fusion-360-like-Inventor
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
melvinbrian3d
Thankss ill vote Too!
MelvinBrian3D
