I got a work around to this problem from a user on Reddit. However, the solution we came up with doesn't seem "right".
The project is cutting out a shallow arc from a large piece of foam. I've included a screenshot of the drawing where I got stuck. What I'm trying to do is dimension the height of the curve relative to the bottom of the body at a regular interval along the x-axis, every 12" would be enough. I've tried adding construction lines and points to the sketch in the design space but none of those are carried along with the body when I make the drawing. The hack that eventually worked was to create extruded individual bodies 12" wide in the design space and use that segmented body to give me edges in the drawing space to dimension. This seems inherently wrong. Yes, I got the result I wanted but I had to modify the model to make the dimensioning work in the drawing.
So, how do I dimension the height of a continuous curve at regular intervals in a drawing?
