How to design a curved plane
googliola
googliola
Hello
I'm struggling to reconstruct a small piece for an RC Car.
How would you suggest to go about to achieve the structure in the picture? I could extrude, then use a curve on a sketch to cut it, but that won't be exactly what the original looks like. There has to be a straightforward solution, but I just can't see it.
(My plan is to create top and bottom arm independently, then merge the bodies at the end. I have little to no exp in surface / mesh modification, just solid. Maybe there is an even easier way to thicken the arms in one of those two editing modes?)
Any hints are much appreciated. Thanks
wersy
I would do it like this
TheCADWhisperer
@googliola
g-andresen
If it is to be a curved base profile, that could work.
günther
googliola
Thanks a lot. That is really helpful. Slightly more complicated than I expected, but the result is perfect.
