11:19 AM
- Mute
- Permalink
- Report
I know I should be able to figure this one out, especially after 20 days, but how do you define the dimension of a part? I can press/pull, but that only adds or subtracts. I want to click on two faces/edges, like the top and bottom of a cylinder, and define the length.
If anything the press/pull only adds to the confusion as my cylinder is 20mm, but when I select press/pull and click on a face it says 10mm, 10mm from where to where, the cylinder is 20mm not 10mm and it hasn't added anything yet?
