How to create twisted objects?
alphatester77
alphatester77
Hi all,
Saw this tutorial and thought the twisted vase effect looks great. Noted author said this was made using fusion 360.
https://www.instructables.com/The-Neopixel-LED-Vase/
Anyone know how to create a twisted effect like this in Fusion 360?
Know how to do this in 3dsmax, but stumped as where to start in Fusion
jhackney1972
Here is a simple vase with a captured fiber path.  The path is on a 30 degree twist along the path which is adjustable as well as the count.  If this suits, then I could do a Screencast on the process.
John Hackney, Retired
wmhazzard
Here is one way of doing it. It uses a sweep of a profile along a split surface as a path.
TrippyLighting
If you are comfortable doing this in 3DS max, then check out the T-Spline/Form modeling tools.
