Hello! How would i create ribs (connecting structure for 3d printing, but not supports) from each corner of the center hexagon to each partition? I'd like each partition to be attached to the center hexagon corners by an arc.
Solved by laughingcreek. Go to Solution.
not real sure what you mean. lets start with the attached. if this isn't close, maybe you can sketch what your looking for and post a pic
@SuzukiGS750EZ wrote:
Yes, how did you do that?
have you stepped thru the timeline and studied how things were done?
the profile is in sketch2, and it was extruded in extrude3
I went through the timeline but it's a bit beyond my level currently to comprehend lol
