HOW TO create recess feature question
infoCJPYC
Message 1 of 8
infoCJPYC
I have this part i am making and i wanted to ask how i can create the feature face showing in the picture. i have sketched it but i don't know the workflow to create it on the body.
\thanx in advance!
Replies (7)
Message 2 of 8
TheCADWhisperer
@infoCJPYC
Sweep
Message 3 of 8
kacper.suchomski
(view in My Videos)
Kacper Suchomski
Message 4 of 8
g-andresen
I would create a solid sweep with a real v-bit-tool.
(view in My Videos)
günther
Message 5 of 8
infoCJPYC
Thanks for the answer. Learned something new. Great
Message 6 of 8
infoCJPYC
Thank you. great solution
Message 7 of 8
infoCJPYC
it's solved now but thank you for your interest
Message 8 of 8
johnsonshiue
Hi! There are multiple ways to create the desirable geometry. Here is another approach to consider. Basically, create a Variable-Radius Fillet with both ends having zero radius. And add two points proportionally with equal radius. Then go to Surface tab -> delete the filleted faces. Create a Loft surface to fillet the gap. Stitch them back to a solid body.
Many thanks!
Software Test Engineer
