How to Create Oral Retainer from STL Tooth Scan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to 3D print an oral retainer based on a scan of my lower arch. I have attached both a screen shot of my STL scan and photo of the desired final result. [The forum did not allow me to attach the actual STL file; invalid extension]
While I am quite familiar with parametric modeling, I have hit a roadblock doing anything useful with a triangulated STL scan of my lower teeth. Conceptually, I'd simply like to "offset" the scan of the surface of my teeth to create a 1.5mm-thick body. I would then clean that up to create the retainer that looks similar to the attached photo.
I have tried enough to understand that I cannot simply "offset" a mesh. In fact, I have yet to be able to anything useful with my STL in Fusion 360 other than add it to my file. I have poked around in Sculpt and Patch for hours, but haven't found what I need yet.
- STL is triangulated with about 300K verticies
- Tried to use Instant Mesh to convert to quad but it apparently doesn't accept STL(?). If I had been successful, I would have tried for under 10K vertices, but I could not import the STL to that application
- I am not interested in just printing my arch and vacuum sealing a retainer
- Yes, I will use dental resin for the final product
- Yes, this is being done under strict supervision of my dentist. He knows dentistry but not this type of technology
I appreciate you helping me understand what needs to be done to make my tooth scan useful and any ideas you might have on how I could essentially achieve the effect of 1.5mm offset to create the pictured retainer.
Thanks so much!
