- Mute
- Permalink
- Report
I need to create offsets to take into account the kerf width of a laser cutting process and the need for several passes around the same path. The application is for a resistance heating element that will be laser cut (example attached), so the path is very complex. I first tried a basic offset of the DXF, but Offset wasn't working (it just gives an error without further explanation). I then tried to create surfaces in the Patch environment, which worked, but seems to have stopped working when I tried to fix an error in the file I created a few weeks ago (Fusion just locks up or gives an error). Does anyone have any strategies that I can try short of manually offsetting every curve (the example shown below is a very small section of a much larger element)? I need to export the path as a DXF, so I don't think I can use the CAM milling features.
