- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is a learning project to create a model I can 3D print to repair an electric toothbrush.
I've started over on this from scratch to reinforce the little I do know and to make a cleaner design.
At this point I need two locking lugs 180 degrees apart on the inside surface near the base. they need to be rectangles and mirrored. I need to be able to rotate them and adjust the dimensions and distance from the base as a single unit. I have attempted several times but cannot get the effect I want.
