How to create gears between two defined points
maorbiton9654
maorbiton9654
I have two drawings of a circle I want to create from them gears that will connect to each other, how do I calculate the appropriate wheel size?
TheCADWhisperer
Where will the gears mount?
Do you have a center-to-center distance for the mounting shafts?
Do you have a desired gear ratio?
maorbiton9654
I need a 1: 1 ratio, the wheels should be in the center of the marked points1.PNG
jhackney1972
You did not specify the Pressure Angle or Module for you gears.  The center distance, in the supplied model, is 67.082.  With a 20 degree pressure angle and a 2.0 module, this center distance is too large for two 33 tooth gears and too small for two 34 tooth gears.  Attach is your model with the 33 tooth gears mounted.  The gears are motion linked together.
John Hackney, Retired
etfrench
You also need to indicate how much power needs to be transmitted.
The following gears are close:
  • DP (Imperial) 96, teeth 254, pitch diameter 67.2041
  • DP (Imperial) 96, teeth 253, pitch diameter 66.9395
  • DP (Imperial) 48, teeth 127, pitch diameter 67.2042
  • DP (Imperial) 48, teeth 126, pitch diameter 66.675
  • Module 0.8 (Metric), teeth 84, pitch diameter 67.2
Notes:
 You will have better luck designing a mechanism where at least one gear is adjustable.
 Can you measure to 4 or 5 decimal places in Imperial or metric?
ETFrench
