How to create components with variable parameters?
I need to create 50+ parts which are identical but must all have different dimensions.
The length of each part must be adjustable along the red line in the image below.Screenshot_1.jpgWhat would be the most efficient way to go about doing this for a large amount of parts? Thanks for any help.
SwApNiLbAd
Hi @shazi.asher00 you should use scale option in which you have to select non uniform option for increase the size along lenght
hope this will help you.
lichtzeichenanlage
IMHO scale isn't a good option, because it might mess with some dimension you don't wont to be changed. Perhaps you might want to check the FusionSheeter Add-in. This allows you to maintain and name different configurations, change the current design or batch-export them.
Thanks for the suggestion. Unfortunately, it poses 2 issues that I would need to face:
  1. Scaling the entire part along an axis would also change the size of the holes, whereas I would need the holes to maintain their scale and only change the length of the midsection.
  2. I would need to find a unique scaling factor for 64 pieces (for my particular project) and apply it one at a time, but I would rather avoid this repetitive process in lieu of a more efficient method.
Ideally, I would be able to come up with the base shape and specify the length as a variable parameter, and then duplicate the part a certain number of times with different values used each time.
This looks more along the lines of what I need I will take a closer look into it at a later time, but for now, would you know if this method allows me to duplicate the same item with different length parameter each time?
I watched the video but it shows primarily the use from a spreadsheet into Fusion360, which is also useful for my case.
lichtzeichenanlage
Sure. You can either manipulate user or model parameters. If you sketch contains a total length parameter than you can manipulate this in the spread sheet by defining 50 sets.
