How to create a wave pattern on a cylinder
ianhughes7UFVF
Message 1 of 15
ianhughes7UFVF
Hi
I am trying to reproduce the wave pattern on this design:
The wave shape has 6 peaks and sits between 21.5 and 25mm.
I have created the basic shape in fusion:
But to create the dips I am not sure about.
My mind thinks I would find it easier to do a sheet metal unfold and create the 6 dips and 6 bumps in that, and rewrap it.
Is that how I should do it or is there a correct way.
Any directions would be appreciated.
Regards
Ian
Replies (14)
Message 2 of 15
TrippyLighting
See here for example
Message 3 of 15
g-andresen
This can best be done as a sheet metal construction, like here.
The wave profile was created freehand without dimensions.
günther
Message 4 of 15
TrippyLighting
Here's another modeling approach:
Message 5 of 15
laughingcreek
Message 6 of 15
ianhughes7UFVF
Hi
I have completely forgotten how to do this but like your example I created the split cylinder and in sheet metal I am trying to unfold it.
When I select unfold the cylinder goes transparent and becomes non workable.
Any help would be great. I am sure I have missed a vital step.
Regards
Ian
Message 7 of 15
davebYYPCU
To fold and unfold, you have to create Sheet Metal bodies,
but I prefer Trippys method.
Might help....
Message 8 of 15
ianhughes7UFVF
Hi
I am having trouble with the Sculpt method and would like to try Gunther's method, but I carn't see exaclty how he did it.
I can see a split circle that creates the split in the solid, but I carn't see how he goes from there to the unfold.
This is the missing part that would help me create the part.
Could you do a step by step Gunther at all?
Regards
Ian
Message 9 of 15
TrippyLighting
@ianhughes7UFVF wrote:
Hi
I am having trouble with the Sculpt method...
Maybe you want to take a step back and NOT look for a different method until you've mastered to implement this one and fully understand what it does.
Once you understand the limitation of the method itself (and not just you own limitations in implementing it) you will be much better equipped to make decision yourself as to which method might be appropriate to solve a particular problem.
Message 10 of 15
g-andresen
Hi Ian,
here is the file:
günther
Note: Do it, as @TrippyLighting  sayd, with both methods.
Message 11 of 15
ianhughes7UFVF
Hi
Still unable to create the flat pattern in the sheet metal side of fusion I watched a video on youtube where the chap created a flat pattern from a cylinder.
He explained that fusion doesn't like to make flat patterns from cylinder shapes so he found the split edge of the cylinder and created a sketch on it and extruded a micro surface from it. Then selecting 'create a flat pattern' he was able to flatten the surface out.
Well I tried making the cylinder from scratch and create a sketch and extrude on the flat surface but the 'create flat pattern' won't do anything.
This intends to fight me I think.
Helllllppppp 🙂
Regards
Ian
Message 12 of 15
davebYYPCU
Did you read message no.7 above, or forget,
You need a sheet metal body, to allow a sheet metal function to operate, this file has a solid body.
Might help....
Message 13 of 15
ianhughes7UFVF
Hi
I didn't get a notification of those messages, but I just tried Gunthers method and it works.
Sorry about that, a bit slow on my end.
Regards
Ian
Message 14 of 15
MichaelT_123
Hi Mr Ian Hughes,
The simple universal method:
- create XY sketch
- create two line segments with angles in XY, XZ, YZ to suit your needs
- create two circular patterns out of them
- loft a surface using resulting lines
- cut your (designed) body
Please find attached file. It should be self explanatory
https://a360.co/2ZywpEw
Regards
MichaelT
MichaelT
Message 15 of 15
g-andresen
Hi Peter,
thank you for your suggestion.
Here is a result that came out of it:
günther
