How to create a sheet metal design from finished sketch
treahuggs
Message 1 of 19
treahuggs
I am designing a motorcycle license plate holder, because of the shapes it feels like it would make more sense to draw the entire flat piece out first THEN bend it in fusion. However, I cant seem to figure out how to make that work, every tutorial i've read and watched start with basic shapes.
Is there a way to use sketch lines to direct my folds or should I use another method?
Replies (18)
Message 2 of 19
laughingcreek
you do use a sketch to direct the bend function.  but it doesn't generally make sense to start with the flat pattern and bend it unless you already have a flat pattern where all the bend allowances have been figured for you. (ie,, you have a library of flat patterns produced by other means, and you want to get those designs into fusion.)  it makes much more sense, and is WAY easier to model it in it's finished form and then unfold.
Message 3 of 19
Drewpan
The whole point of doing a model and then converting it to sheet metal and then
creating a flat pattern is to avoid what you are trying to do in reverse. If you actually
MODEL the design then fusion can easily work out where the bends are and what the
angles are and what allowances to make for the bends. If you flat pattern FIRST then
how does fusion work out all of this stuff?
Sure, this "might" be able to be done starting from a flat pattern but if you are going to
do it that way then you might as well continue and make a bend template for the
machinist and hand it over. Sometimes the traditional way is the hard way. This is a case
in point.
I would either start again and model this as a Solid and convert it, or I would start it as
a Sheet Metal part and build it with the flange commands.
Cheers
Andrew
Message 4 of 19
treahuggs
I did end up using the flange feature from the bottom up. To me it still seems easier to tell fusion what lines to bend on and then it rotate your sketch to the new planes.
How would you do a bend similar to this one in fusion? (pictures attached)
Have my folded part all made but now I am getting "Error: There was an unexpected problem with exporting the flat pattern as a DXF file." with zero indication where the issue is occurring. I suppose that is an issue for another topic however.
Message 5 of 19
Drewpan
Export your design file from the fusion file menu and attach it so we can have a look.
It will probably be something simple.
Cheers
Andrew
Message 6 of 19
user015M86Y
@treahuggs ,
See attached my proposal with your flat pattern and bend
Need your sketch dimensions to achieve what you want
Is there more bend ?
Message 7 of 19
TheCADWhisperer
@treahuggs
What process will be used to cut the edges (currently you show zero kerf)?
Do you have a picture of a similar holder from the real world?
Message 8 of 19
TheCADWhisperer
@treahuggs
Message 9 of 19
treahuggs
Attached is my design.  Since I couldn't figure out how to do the unique bends I just kept the top part flat and was going to try a manual bend on one axis instead of my two axis bend like my picture. Unsure if I need two bends till I do more testing.
Message 10 of 19
TheCADWhisperer
@treahuggs
Before I spend a lot of time on this - are you basically satisfied with the outcome - or would you be interested in learning more about how to do this correctly starting over from scratch?
Message 11 of 19
treahuggs
So far I am satisfied but I would love to learn how to do bends like user015M86Y showed. The more I learn the less I have to ask!
Message 12 of 19
TheCADWhisperer
@treahuggs
I don't really understand your Design Intent as you were missing many dimensions - but use symmetry about the Origin and fully define your sketches.
See Attached...
Message 13 of 19
user015M86Y
@treahuggs @TheCADWhisperer
See attached my proposal with sketch flat pattern and bend
I used parameters to define the arc length according to the different angles
@TheCadWhisperer what do you think
Message 14 of 19
TheCADWhisperer
@user015M86Y
I am getting a better idea of the true Design Intent.
The problem with Bend is that first a lot of work goes into creating the sketch, and second the Bend Allowance is not calculated so the end result dimensions are not known.  The finished part is what the customer measures for specs.  They don't care about the flat pattern, only the end results.
I have an idea of an easier technique to model that I will try to demonstrate tomorrow after @treahuggs gives input on these two examples.
Message 15 of 19
user015M86Y
@TheCADWhisperer
Thank you for your comment : in fact it is exact that the creating of sketch require lot of work
I am waiting your easier technique
Message 16 of 19
TheCADWhisperer
@user015M86Y
The starting sketch could be as simple as this...
This defines the length and angles of the faces and the bend positions.
Create Flange of minimum width and then add/cut as needed to complete.
Message 17 of 19
user015M86Y
@TheCADWhisperer @treahuggs
In the meantime, I made a variation using the sheet metal flange and bend
I preferred to use the Hole function which allows not to make a sketch
Fusion lacks the possibility of making a rectangular, square, polygon hole without using a sketch
Less work and certainly closer to the final plan
Message 18 of 19
treahuggs
What  user015M86Y  posted is what I would like to learn how to do. The complex bends
Message 19 of 19
drl767
Community Visitor
Community Visitor
I have a scenario where it makes more sense to model it flat first, which is how I found this thread. I already have a part and process to make a part where all bends are in the same plane and orientation. I start with a rectangular blank, and using a manual steel rule die type bender, I make all bends starting at the farthest bend in from each end, working my way back out to the edge. All bend dimensions are held from the end which makes locations accurate from the same (and only available) datum. I have a starting blank size and all the bend locations, angles and direction. I would like to parameterize a model in fusion to work like the machine I make it with works, known bend dimensions off the outside edges. To make it more difficult, my part has a large radius cylinder on it which I don't know how to tell Fusion to bend from flat. I have to do a flange extrusion from a sketch of a circular arc of 350 degrees.
In any event, assuming I figure out that part, It would be valuable for me to model in this way as that's how I have to manufacture it.
Additionally, I would like to model the basic geometry of the bending machines to look for interferences while bending. It would be very helpful in making alternate models of the product to be able to model the motions, and potential machine interferences in order to modify the design and or have different orders of operations to make complex shapes work without physical trial and error.
Dean
