How to create a screw conveyor
I need a screw conveyor in my project. Can someone please help me out?
Marvin
Here's what I came up with using the cylinder, coil and press-pull features.
  1. Create a cylinder for the central support.
  2. Create a coil, with a square section around the cylinder.
    • The diameter should be the outer diameter of the screw portion of the conveyor.
    • The section size should be the desired thickness of the screw portion of the conveyor.
  3. Modify > Press Pull (or press Q) to do a press pull.  Zoom in and select the inner side of the square coil.  Pull it in towards the cylinder until it meets or overlaps the cylinder.
  4. Modify > Combine and select the two bodies (cylinder and coil) to make the screw conveyor.
Jonathan
I tried to do the step 3 but when I select the inner side of the coil and move the cursor towards the cylinder, fusion gets an error. Can you still help regarding this? Thanks in advance.
Marvin
lichtzeichenanlage
I'm a beginner in F360, CAD etc. I would do it like this:
lichtzeichenanlage
I've forgotten to attach the export..
Thanks lichtzeichenanlage! Another good perspective.
Thanks Jonathan! I found the solution after hours of trying and I followed your timeline.
