How to create a duplicate sketch above or below the reference object (plane) ?
I want to create an object that sweeps from one plane to another.
I tried using a box, but it creates a hollow cylinder.
So here is how I would do this as an example:
1)  New component
2) On plane#1:  Draw two 10mm x 10mm square touching each other.  This would be same as a 10mmx20mm rectangle.
Then draw a circle on left side square touching the sides of the square.
3) How do I do this (3a)?
a) On plane #2:  Now duplicate ALL sketch objects in step#2 on a plane at 40 mm offset vertically above plane#1?
b) Then I would draw a circle on the right square of plane #2.
4) Sweep line:  Draw line from plane#1's left circle's center to plane#2 right cricle's center.
5) Do sweep from bottom left circle to top right circle.
Now I get a solid cylinder that is tilted.
Side topic:
Is it also possible apply rectangular pattern to 3D objects like you do to 2D sketches?
Thank you.
TrippyLighting
The nswer to that question is very similar to your other thread with drawing a line betwen two arbitrary points.
Once you've created these two sketches on two offset planes, create a new sketch. it does not matter on what plane.
Whn in that new sketch select "Sketch->Project/Include-> Include 3D geometry". then you can simply draw a line between the center of these two circles in the two differnt sketches.
I could not find the other thread. Somehow it is missing on this forum.....
lnonnato
Hello ilikef360,
What you want to do is really easy and it is well explained in the tutorial pages.
Anyway, if you just want to construct a slanted cylinder, you are following a very convoluted process. Just draw the first circle, offset the drawing plane, draw the second circle and make a loft using both circles. This is explained below:
a) select a plane and create a sketch
b) select the center diameter circle tool, choose the center and draw the first circle (if you want, draw the two sqares); stop sketch
c) select Construct / Offset Plane; select the first plane; enter the offset value; press [Enter]
d) select the second plane, create a second sketch, select the center diameter circle tool, choose the center and draw the second circle; stop sketch
e) select Create / Loft; select both circles (be careful to select the circles themselves, and not their boundary lines); be sure that Operation is New Body and click OK
f) you have a nice slanted cylinder
If you really want to project the geometry and draw a line connecting the circles centers, you will have a little more work:
- first of all, go to Preferences (the small button with your name, at the right upper corner of the screen), go to General / Design and tick the option "Allow 3D sketchingg of lines and splines"
- follow the above sequence of operations till step d; after creating the second sketch, while it is still open,  use the ORBIT cube on the right upper part of the screen to have a clear view of both sketch 1 and 2 (you can select the small home icon); select the tool Project/Include / Include; click on all the lines and points of sketch 1 you want to project in sketch 2; these features should now appear in sketch 2 in a dark red color
- now the tricky part - draw the line between the centers: with sketch 2 open, use the ORBIT cube to have a low-angle view of both sketches (the sketches should be almost normal to the computer screen); select the Line tool; select the circle center in sketch 1; carefully move the mouse around, till you get a dimension showing a vertical angle (see picture); very carefully, while keeping the vertical angle dimension on screen, click on the center of the second sketch circle;  this takes some training
- close the sketch and you have a line connecting the two centers
I hope this helps.
Cheers,
Luiz
Luiz:
>>"I hope this helps."
thank yoiu .
It helped a whole lot!
Thank you for the generous time, and for writing it down step by step.
The step by step is a HUGE help.
I have trouble following videos!  😞
IGNORE THIS Question:  Is it possible to create a rectangular pattern (duplicates) for 3D objects, e.g. the angled cylinder here.
I have only seen it done for 2D sketch objects in tutorial.
Addendum:   I found answer here.
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-9622573F-06FA-462F-AFA7-97CD0C7AA0C9
TrippyLighting
Yes, use the "Create->Pattern" menu.
Thanks.
