How to create a cone ?
SimonPlatten
Message 1 of 13
SimonPlatten
I've scanned in a human head with mouth open...I've imported the scanned head into Fusion 360, now I want to add some vampire like fangs to the model, I was thinking of using cones.
How do I create fangs to add to the model?
Replies (12)
Message 2 of 13
davebYYPCU
Short answer - Loft to a point, with centre line.
Might help....
Message 3 of 13
SimonPlatten
Thank you , I'll give it a go.
Message 4 of 13
laughingcreek
Here's a screen cast of 3 different methods.
Screencast will be displayed here after you click Post.
286a8474-4d5c-494c-8314-b0b0a32d146d
Message 5 of 13
laughingcreek
maybe it will attach this time
Message 6 of 13
henrycasson
Also you can rotate a triangle about one side
Henry.
retired Doc.. should have been an engineer.
Message 7 of 13
SimonPlatten
This is good, now if I want to sculpt a tooth, how do I start?  Is there a tutorial on sculpting?
Message 8 of 13
laughingcreek
Here's a screen cast of sculpting a fang.  There are a lot of tutorials on sculpting, I don't have a specific one I can point you to.  Using sculpt looks easy and straight forward, but that's a bit deceptive.  There are a lot of things that go into making a more complicated sculpted form.  I suggest watching a lot of videos of people making sculpted forms.  Probably the best way to learn.
I (and other on this forum) have noted that some tutorials (particularly from AD) use sculpting techniques that are not ideal, so be careful.
Getting the topology right will be of prime importance.  I usually start with that, and then shape it into the final form.
Message 9 of 13
laughingcreek
one more try at the screen cast
Message 10 of 13
SimonPlatten
Thats absolutely brilliant, thank you so much!
Message 11 of 13
SimonPlatten
When I open Fushion 360, I don't have a Scuplt option...how do I get it ready to apply your magic?
Message 12 of 13
jibberjack
Click on the purple Create Form button above the create pulldown icon. If it's not there, then it's at the bottom of that same pull-down and it will take you into the Sculpt workspace. I don't know why it's not an option in the workspace pull-down along with the other workspaces. I'm sure there's a reason for it. I'm still new here.
Message 13 of 13
SimonPlatten
I've been trying to follow the video, but with no audio its very difficult to follow.
