Hi @Anonymous
Welcome to the Fusion 360 online community! Thanks for posting. It looks like you would like to copy a sketch from one component to another and then edit it.
I have explained a few different methods to do so in the screencast below. Please let me know if this helps and if you have any other questions!
Hi Paul,
My end goal is to produce drawings from which I can built a model ship out of wood.Getting a little bit familiar with Fusion 360 I started with creating construction planes with the frame sketches.Then there was the struggle to get these sketches fully constraintMy first attempt was to create a solid hull
Changed this because problems into creating a ( one) shape/face I added the waterlines
Found out they had to be coincident with the frame lines
I reached my goal with creating faces between to frame lines
Afterwards understanding F360 a little better I now know I could use multiple frames
being aware that the rails MUST BE connected with the frames
I thaught to merge -Merge edge- all faces/shape to one face/shape
and then thicken that one face/shape so creating a solid which I can use for the outside planking
but still I must select all the shape
Then I noticed I missed RULE#1
So first I want to copy all into a component
Then copy the complete -to say construction plane & sketch- component to create a solid
Then I have to modify each sketch to get a solid
In the image you see There are a lot frames
Having the solid I can copy it into new components
By slicing or cutting I then can create each unique frame
If You think there is a better way to do is
Please advice,
regards,
Pieter
Hi @Anonymous
Thanks for the response!
While I am a little unclear on the issue here, one thing that occur to me is that if you used the "Paste New" command when copy/pasting an instance of the frame you could use the new (copied) sketch to meet the unique form of the new frame instance. I have illustrated this in the screencast below.
Hopefully this helps! Please let me know if you have any other questions - it may help me troubleshoot this issue if you could share your model here or in a direct message if you require further assistance.
